installing hv3/fuel rail ?s
Jakegday
hello guys. im about the purchase an hv3, and im reading through the procedure for removing the upper intake manifold in my service manual. everything sounds do-able to me except there is 1 area i have no experience in. it says im supposed to remove the fuel rails, and injectors. im basically wondering how do i undo the "feed" and "return" quick connect fittings, and also, it says to use a special tool when removing the injectors. is that necessary? or how do i remove an injector exactly? do they just pull out? are they locked in somehow?
thanks in advance.....
Just unbolt the whole fuel rail assembly, 4 bolts, and pull it out of the manifold and lay it aside, leave everything connected.
