Newbie has a couple problems...
gggromit
Hey all, I'm new here-- I'd like to start off by saying hello. My name is Cal, and I'm 19 years young living in the Niagara Region of Ontario. I sport a Galaxy Silver Grand Prix GTP, and I love it to pieces. I already see there's another member that lives close by who drives a nice black GP... very good looking. I'm pretty sure I've seen you rolling around once or twice... :th_peaceout:
Looks like a great site, lots of info-- so I'm hoping I can pick some more knowledge from you all :)
Lets just say today was pretty crummy in regards to my car. A couple major problems popped out of nowhere.
First off, my ABS light and TCS OFF light have come on. I'm pretty sure it's a bad hub (love GM for making sealed hub sensors) but I have yet to get it scanned. My logic behind this is when I get up and above 130km/h, my car begins to vibrate quite noticeably. Nothing fierce, but you can feel it in the seats and see it in the dash. I'd tried to clear the code by doing a reset (unhooking the negative terminal on the battery) and it worked for about a 10-20 feet before disengaging again. The next thing I'm gonna try tomorrow is a visual inspection... any help in diagnosis is appreciated. I know GP's are ridden by this ABS horror story all through the years. :)
Secondly, my power steering (I know because the ABS is non-functional, the MagnaSteer is disengaged...) tank has run empty... giving me a nice squealing from under the hood as the car screams to turn. I've topped it off with Lucas Power Steering Fix... and I'll see where it goes from there. I'm assuming it's a bad seal or a line that's been snagged and ripped, so I'm hoping it's nothing major.
Third, my A/C no longer works. Sounds like the compressor clutch is not engaging, so I'm hoping a refrigerant recharge will fix it... any thoughts?
After I can resolve all this, I'm looking into beginning the modding stages... :) I'm a rookie when it comes to cars, but I know enough to keep it maintained. The only mod I have is that I have a K&N Cold Air Intake, and nice Perelli's, haha. :th_biggrin2:
Thanks in advance for your help and input!
Cheers!
Cheers!
Don't forget as you do a visual inspection to also check all the connection ( i unplugged and then plugged back in then mine turned off)
From my experience with the 97-03 gp's, It's usually as you said, simply the sensor that does this. If you have time, check your sensors to make sure they are still all connected. I was able to just reach behind the tire and check mine but I had changed them a few times so I knew right where to feel. I'd say to get under there and give her a peak. If they are hooked up, one may very well just be shot. I don't know if anyone on here has found a way to replace the sensor itself, but I've had to change the whole hub when it happened to me... lol
as far as power steering issue, can't help you out there.
ps. Where you from in Niagara?
nice, nice. I don't spend much time in grimsby, one of my ex's lives there, but that it. haha
I know that the boys at www.owcgp.net meet in grimsby for coffees some times.
So I got my ABS scanned today, all the WSS are okay... he mechanic tells me its a communication error between the ABS module and the ECM?
He said to check the wiring harnesses but there's a few I'm reluctant to try... and pointers?
