Need help wiring amp
jjwitty
Any easy non-destructive way to get a amp power cable thru the firewall on a 2006GP. got everything hooked up but that
wrong place to post a thread about wiring instruction...post this under tech tips or general tech discussion to get a quicker response!.. :)
alright this car is super easy to do.lift up the carpet in the passenger footwell where the carpet ends, you will find a rubber grommet with alot of wires goin through ittake the rectangle grommet out and then get ur wire through there.i wired my amp through the center console and under the back seat and through the bottom of the back seat door
but when U find that hole with the rubber boot u'll have to stick a screw driver in there to wiggle it to stretch the rubber so ur ( guessing ) 4gauge wire can fit. I started with engine and went into passenger firewall ( more near middle of car ). peeled carpet back and ran thru the middle console, under the carpet to under the rear seat. good luck and welcome.
