getting my projectors soon....HID question
gotboost3
what hids are you guys running in your projectors...are they 9006 bulbs? and how does wiring it up work for the projectors?? pics would be greatly appreciated :)
You need H1 bulbs fof the projectors. Its not worth it to upgrade the high beams. The high beams are 9005. I am using a 9007 bi-xenon relay harness with mine. Its completely plug and play.
the projectors are junk, they will always bounce on you like a girl with big cans running. you'll see
wait a 9007 bulb can go into the H1 hole for the projector?
What a load of crap...
projectors sofar have been one of the most bang for the buck i have had...
do the bounce removind mod. I have zero bounce
Hmm. I know the halo lights I got had to be wired goofy. The positive wires to the negative and vice versa. It was the only way to get the xenons to turn on. I wired the halos straight to the power cable that the xenons are wired to. Guess I have it ghetto rigged? Or I got the cheapies?
you wire the red on the halos to the brown wire on the big signal bulb and the black on the halos to the black wire on the big signal bulb.....the halos are powered by leds and leds only light up with current flowing one way through them...so it has to be wired + to + and - to - in order to light up they are not like halogens where the direction of current doesnt matter..
Yeah the Rings weren't too hard to figure out. It was the Xenons that was confusing. The instruction manual had 4 or 5 different ways to hook them up. None worked. Had to look up directions online.
