PRJ rails and full size IC...
I'm running a Full IC, PRJ Rails, and AN-6 lines, no hood clearance issues whatsoever.....
Here is a closer pic on how my regulator is mounted....
Iron Indian, are you lowered? I've got the GMPP/Koni setup and the ZZP offset polys. I'm wondering if I'll have any issues with the full IC and hood clearance. I'm sure I'll need the cradle spacers.
BTW, that custom tensioner is pretty bad ass.
I'm stock ride height. I personally don't have hood issues with my slightly taller aftermarket hood. Besides, my core is 2.00" tall which helps.
The offset mount may cause issues with clearance if you're gonna run a ZZP style core which is 2.25" tall under a stock hood.
i run cradle spacers, although i might not need to now, only had a problem with my original intercooler, was 2.5 inches high, since then have made them 2.25 inches tall.
Thanks for the info. I'll probably have to run cradle spacers. Not sure how that will affect my axle geometry with me being lowered and having offset mounts. Maybe I'll be eating up axles like no tomorrow.
yea, probably wouldnt advise that, youll be good with a 2.25 inch core i promise.
Well, offset mounts is the equivalent of raising the motor. The cradle spacers would lower the motor. So technically, the axle geometry would really be pretty close to stock. I may just have to end up selling the offset mounts and running a set of regular poly mounts.
yea, you should be fine, it measures 2.25 inches so i see no problem with it, but you never know, every car is different. if not, i sell cradle spacers as well, $20.
