ALRIGHT, A milestone has been made in my garage at 3:35am haha.
Hooked up everything I have to it right now. Ignition, Fuel, Power, MegaSquirt-II board, and we're ready to crank this sucker.
Here's what we got so far:
Configured the EMS board to go with my engine. Set up injection properties, TPS, temp sensors, all that good stuff. As soon as the TunerStudio started, was a snap to adjust the TPS accordingly, and the temp sensors automatically detected their proper values (MAP, IAT, all that good stuff).
During cranking, it made a HORRID screeching sound (metal on metal), so a look at the starter, and it was discovered there wasn't a starter bolt in place, so stole one from the old engine, and jus like magic, fixed.
I've uploaded a video of the first crank to show you guys what I'm dealin with
YouTube - L32 First Breath of Life -- Crank, but no start
This is my issue now. After cranking, we discovered that there is an ignition issue. Unscrewed the spark plugs to make sure the injectors are squirtin (which they are), and there is proper fuel pressure (...i have the red eye to prove it when I unscrewed the fuel line expecting a faulty regulator).
Sorry that the image i made is a little small in the text, but basically, I have the Cam and Crank "Sensors Ign Pos" wires spliced together and into Pin 24, and the "Sensors Grnd" spliced together and into Pin 2. And from the module, i have the "IG CTRL" wire into Pin 36 on the MSII board. Any suggestion from any1 who knows electrical would be very helpful. I'll post the Megasquirt wiring diagram as well for reference.
