PN for brighter taillight blubs??
Iron Indian
This info used to be posted on the Canada Club GP but its gone. There was info for bright blubs inside and out, one was tail light blubs (good for guys with darker tails). Anyone have this info?
Thanks
Shawn, I dont have an answer for you, but I am going to watch this thread because we had a discussion going on about the affect of tinted tails on light output, particularly during the day.
i'm sure there must be some brighter bulbs, but with brighter comes more heat... i'm sure there's a fine line in there that might be too warm
though i remebmer seeing somewhere 55W backup lights.....
Bringing up the heat is a good point. I wonder if there is anyway to determine where the cut off point would be other than real world experimentation?
i suppose if we found a chemist that was familiar with the specifications of the plastic used in the tail lights....
:D
but, i suppose there is a decent amount of space in the light, so it shouldnd be THAT sensitive
I was thinking about that earlier. One on top or over the top of the bulb would be good, but then, of course, you have the possibility of water intrusion. You could put one on the bottom but , of course, heat rises so it probably wouldnt be all that effective.
You would be better off with something that gave you a little air flow I would think.
Well if that is the case, I may have to find me a spare set of tail lights and try that out.
you'll still need to add in the resistor modules, if you dont want to hack up your flasher.
--- but ---
guess what?
i've come up with a plug and play solution for the resistor modules :D
LEDs are NOT brighter than bulbs in housings designed for bulbs. Same principles apply for installing HIDs into reflector housings. LEDs are a point-source emitter, not a spherical light source like a tungsten filament bulb. The 3457 bulb is the brightest of the 3x57 class of S8 dual-filament bulb. 3157 = 32 MSCD, 3457 = 40 MSCD. By comparison, the 9007 bulb is rated for 80/107 MSCD. You can also modify your flasher module to accommodate LEDs in any combination, rather than hack up your wiring by installing those silly load resistors...
