Ok here is my dyno. Why aren't these the numbers I should be getting?
I dunno about the dyno results. Actually I'm goin to the dyno tomorrow so ill let u guys know what I get. I've got a 3.4 pulley, cai, zzp pcm, 180 tstat, tb spacer(bluh), 3" catless dp, plog, 8.5 mm wires, autolite 104s. So I hope to make decent power. ill let u guys know. And soon ill b goin to the track before it gets too hot. Good luck at the track bro
You've got a DHP man, no way I'd sell you a ZZP PCM...I don't want other cars to blow up like mine did ;)
You need to make it out to KCIR with the KCPMC group the next time we go :D
And I still say youz knockin' bad like I did before :p
Ha! Sorry bout that. Yeah dhp pcm. Crap. Anyway yeah I'd love to get out there. Whens the next time their goin? You know? And I'm sure I'm knockin. Still wanna switch over to headers but oh well. Just got my plog on today. Was pretty easy to put on. Sounds better. But I got a decent jump in performance from it. Plus remember it was free so there u go
Not sure...might be heading out this Friday...so today...around 5 or so. I'll have to call my buddy and see if he is rollin' out there in his Cobra to see what it throws down, he is hoping for 11's. If you go all your need is jeans/t-shirt/helmet/$20 to run all you want to...and if your knocking they have some race gas you can throw in there too ;)
Well right on. Guess I missed that one. Anyway I'm gettin it dynod tomorrow. I'm gonna b goin to kcir sometime next week with my cousin. He's only got a brand new hyundai tiburon. Lol! But, if u wanna set somethin up to go at the same time let me know bro
anyone that has a TB spacer or the threaded/capped off coolant ports on the LIM is making their rear head run hot...
just for your knowledge. you either need to port the coolant passage on the side of the LIM or leave it running through the blower/TB. it cools the rear head that way.
Guys the only knock I have is 0.2KR at my 3-4 shift. That is it. PRJ tuned my car. he knows what hes doing. my car was running lean or rich i cant remember (whichever ones makes your spark plug turn white) is what was going on. he fixed that.
i went to the track last night for the first time. I ran a 15.3 my very first run. spinning like crazy. my second run was a 14.6 and i actually hooked pretty good. my reaction time was .185 and my 60' was 2.13.
im going to scan some things today and see whats up. what should i be looking for on my scans??
Whew. That sucks. Figured ud be runnin quite a bit better than that. Oh well. R u at a weird elevation or anything? Wonder what's up?
what was the mph? reaction time doesnt mean anything. 60' time is what makes the difference. something isnt right if you are only putting down 200 to the wheels
Altitude: 594ft.
Timing at WOT: Near 20* according to PRJ.
Here is the breakdown on my best run:
Reaction: .1879
60ft: 2.1869
330ft: 6.1161
ET @ 594 FT: 8.8221
1/8: 9.4262
1/8 MPH: 74.49
1/4 ET: 14.6690
1/4 MPH: 93.17
I'm putting down 218 at the wheels and 236 TQ at the wheels. This was on a DYNOJET. Someone on here or somewhere else told me that I should divide the result by 1.13 to get the actual because a dynojet reads low????
RESULT WITH ELEVATION FROM DRAGTIMES.COM CALC:--------------------------------------------------------------------------------
Correct your ET and MPH using the DA (Beta Testing)
Density Altitude: 2345
feet above sea level
1/4 mile ET: 14.66
seconds
1/4 mile trap speed: 93
MPH
Stock and Mildly Modified Naturally Aspirated Engines
14.257 @ 95.69 MPH
Extensively Modified Naturally Aspirated Engines
14.396 @ 94.804 MPH
Extensively Modified Supercharged and Turbocharged Engines
14.511 @ 93.955 MPH
no, it is heating up the rear head. the rear head gets part of its coolant flow from the coolant that goes through the blower and throttle body. you need to open up the side of the lim and grind a little out of there so it has that ability to flow more coolant. there is a little cover that is on the side with a couple 10mm bolts.
i was traping 92 when all i had was an intake.
last time out in 90* heat and 2800 DA i was still traping 97 and im on the stock tune and pulley.
somethings not right, are your spark plugs good???
dynojet reads high, because there is no load on the rollers. hence why you divide to get the real number. as for your car, 04's and ups are dogs from the factory. something in your tune is not right. was it "street tuned". or strapped to the rollers and tuned?
