Will a 99 N/A gp maf work ok 98 GTP
the MAF is the same between the L36 and the L67, but the housing on the 97-98s is different than the 99-03s. You could use the 99 L36 MAF only if you have a 99+ TB.
Really. I could have sworn the MAF's were completely different due to the larger bore TB. You 100% sure on that?
He's right. The one from my L36 works perfectly in my L67 TB. Also they're the same part number.
Why would the MAF itself need to be different for a larger bore? It's the MAF table in the PCM that would need to be different.
