ok guys so i thinki found the vac leak.....my trims arre at +16.4 ....but when i spray carb cleaner all around the base of the sc and go check my trims they are at 9.4, and 2-3 mins later they go back to 16.4...now i thought carb cleaner causes a raise in idle and i dont get that....is it possible that the leak is so small that only a very small amount of carb spray makes it in and the carb spray seals the leak momentarily with fluid? im thinking bad sc gasket yeah?
