overheating - loss of power
grand prix newb
First of all I left the lights on at a store, killed the battery I got a jump and was gonna drive the car 25 - 30 miles to charge the battery back up, was driving on the freeway, well after about 10 miles the temp was reading hot, then normal then hot again, and then the power dropped, I could not go faster then 50 mph, I was trying to make it to the next exit, then the car just died, pulled off the road lifted the hood, and steam was comming out, had car towed home, I heard that when this car gets hot the computer would shut things down and that could be the cause of power loss, I changed the thermostat, and noticed the radiater cap was rusted up which may be why the resivoir was allways full. Any truth to the computer shuting down componants and caused the power loss, or do you think I blew a gasket, no water in oil.
I replaced the thermostat, and radiator cap refilled radiater w/coolant, started car, engine shakes has a tick and the service engine light is on.
engine temperture gauge read hot again, fan's came on but the temperture never went down. replaced water pump a few months ago, its not howling or loosing any water from the drip whole, but, does that mean it's a good water puimp? how hard is it to do the hg on these?
Anyone do one on the 3800 series 2 engine, is it better to buy the head gasket set or just the head gasket?
should I be worried about a cracked head?
allthough there is no water in the oil, no steam coming out the engine or tail pipe.
after filling radiater and resivoir,before it got hot the resivoir started leaking coolant out the overfill whole, is that water pump or head gasket?
Got it to stop over heating by bleeeding the system, but check engine light is still flashing and idle's real rough when I push the throttle to about3000 rpm's it really sounds rough and purges, hg maybe warped head, intake leak. what else could get ****ed up from over heating> anybody got anything?
check compression? you can also try pressure testing the cooling system, but I'll bet your lim gasket's leaking at the least. The coolant can get into the cylinders and foul up the plugs, or even hydrolock them in severe cases. Also, any oil/coolant burnt will foul the O2 sensors and plug up the cat, which would also cause the car to run like crap.
Thanks bud,
I got the scaneer, and it read as follows:
1 of 2 -
code P0303, and undernieth code it says Cyldinder #3 Misfire
2 of 2- (Same)
code P0303, and undernieth code it says Cyldinder #3 Misfire,
Why did it say the same code twice? Is it because of two different problems that caused the P0303 Code
Thanks
the first is a pending code, second is a code currently set in the computer (AKA there has been a misfire problem in the past and it is also currently misfiring
Checked spark plug it was a little loose, had black soot on it where combustion was leaking out onto it, was wet with gas, checked, and verified there was spark, will change plugs and wires soon. and update.
Hey if there was a air leak from the intake or head would there have been a different code other then P0303 also?
Kool changed the oil, while waiting for funds to jump up, and I was under car and thinking, and I brought myself back to when I popped off the #3 plug wire from coil, and remembered the coil prong was rusty collored, so I checked the other coil prongs and they were all shiny, so there's my Cylinder #3 misfire prob.
The first P0303 was A loose #3 spark plug, and the second was the coil.
Then I thought about when I reved the engine and it would bog out, and I thought it was a massive air leak somewhere, I took car for a ride around the block and the power was good and strong, so can't be the head or head gasket, or intake.
so in park I reved it from inside the vehicle, and seen it only bogged at around 4000 rpm's, yes it's suppose to, thats the limiter kicking in, what a relief I will get a new coil and update later, thanks for all the help gentlemen.
__________________
I had a similar issue last summer with my 2000 GT. It was slowly leaking coolant over time (my low coolant sensor doesnt work right).
Engine temp just jumped up to max while on the freeway.
I managed to add coolant, and it seemed 'ok' for another month.
There is a plastic 90 degree elbow (newer models have 2 plastic elbows) on that was cracked and deteriorated. It is located on the drive belt tensioner, which is under the alternator.
Get these elbow(s) replaced, part cost is about $11 each from the dealer. It is called a upper and lower thermostat bypass pipe assembly (same part # for both). 1 hour DIY project.
The overheating though, warped my UIM Plenum (I have a N/A, VIN K).
Eventually (month later), coolant leaked into my engine. $1180 went to my local shop to have it fixed.
Thanks I noticed coolant coming out of that elbow and yea both ends of it were corroded and gone, replaced, I too think my Uim is warped, or blew the gasket.
but she's fixable. I am sure I can do it my self, tore apart many engines, time for this one I guese.
How did you come to determining that the UIM Plenum was warped, compression check? or?
And was coolant noticable in your oil?
Cause I see no coolant in oil.
Been a couple weeks since car over heated and mia, well today I go out and check oil and there is coolant in the oil. Head gasket right, or would a warped Uim plenum do that?
My gasket eventually failed, and coolant was everywhere it shouldnt of been.
Had loss of power, top speed of about 50. Shop told me the plenum was warped and needed a new one (~$330 kit), also new plug, wires, oil, and coolant. Half cost went to parts, other half labor. Took them about 6 hrs.
Your talking the plenum gasket right' aside from it being it being warped,
I know when my car overheated I could not go over 50, then it died on the freeway. I can get a new UIM plenum for 137.00 over here in seattle, wa. and fix it myself, just hope thats all it needs.
It's most likely the lower intake manifold gaskets if it's in the oil.
so I should change all the gaskets anyway since its that far torn apart anyway.
when I have the uim off can a auto shop test it for warpness, or do i test it while on vehicle?
Just hope the heads/gaskets are ok.
Oh thank god, it was cloudy and rainy when I checked my oil dipstick, I think my eyes were playing tricks on me, looks like new oil on dipstick, when I checked it a couple weeks ago I thought it looked rusty collored.
http://i276.photobucket.com/albums/kk9/mariog207_2008/DSC00023.jpg
http://i276.photobucket.com/albums/kk9/mariog207_2008/DSC00018.jpg
2 question's
Well eyes wern't playing tricks, I changed the oil to move car, and checked oil again, definate coolant in oil sign's.Havent done a compression check yet, can that be done with intakes off?
AZ looks to only sell lower or upper intake gaskets, can't find a kit online, does anyone have a link for one.
To answer one of your original questions, I know my Grand Prix GTP (97) has what GM calls a "Limp-Home mode". If the coolant temperature reaches critical levels, the computer will shut off half the cylindars for a while to let the others cool off. After a while the computer will turn the dead cylindars back on and turn off the ones that had been running to cool them off. You don't want to drive more than 50 miles in this condition or bad things happen. Obviously there is a serious reduction in power when in limp-home mode. a
Sounds like you did suffer damage though as you have coolant in the oil. You could have damage to head or LIM gaskets or even cracked heads. Run a compression check if you haven't already and hopefully you'll find the issue there. If not, it may be time to tear down the engine to find the problem.
Next time, when the SES light comes on and you see the temp rising, pull over and let the engine cool off. It's much cheaper that way. Also, a flashing SES light always means that you have a missfire.
