2005 Sentra 1.8 Sedan Performance Specs
Performance Overview
- 1,769 cc 1.8 liters in-line 4 front engine with 80 mm bore, 88 mm stroke, 9.5 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder QG18DE
- Unleaded fuel 87
- Fuel economy EPA highway (mpg): 35 and EPA city (mpg): 28
- Multi-point injection fuel system
- 13.2 gallon main unleaded fuel tank
- Power: 94 kW , 126 HP SAE @ 6,000 rpm; 129 ft lb , 175 Nm @ 2,400 rpm
2007 Grand Prix Base Sedan Performance Specs
- 3,791 cc 3.8 liters V 6 front engine with 96.5 mm bore, 86.4 mm stroke, 9.4 compression ratio, overhead valve and two valves per cylinder L26
- Unleaded fuel 87
- Fuel economy EPA highway (mpg): 30 and EPA city (mpg): 20
- 17 gallon main unleaded fuel tank
- Power: 149 kW , 200 HP SAE @ 5,200 rpm; 230 ft lb , 312 Nm @ 4,000 rpm
Fear not my friend, even with his mods he didnt gain 100 hp without MAJOR work to the mill and possibly a turbo kit.
I got an SE-R S.V yesterday, didnt take long to keep him where he belonged.
