If the coupler wears to a certain point, it could either start slipping or actually just break apart, and then the supercharger won't make boost.
One way to find sneaky vacuum leaks is to get a can of carb cleaner.
While the car is idling, spray small amounts of carb cleaner near any suspect vacuum lines/connectors. You'll notice the change in the idle when the carb cleaner gets sucked into the intake.
I've heard of people using propane to do this too. You can use a blowtorch bottle (NOT LIT), and just use it to spray a little bit of propane near the vacuum connections.
-Riggs.
-Riggs.
All of the W-body vendors also sell these green couplers that are a bit thicker than the stock couplers but cost about the same.
They are also supposed to be more resistant to wear. Would be worth checking out if you haven't already.
98silvermist is right too. If the belt is slipping or the bypass is acting up, then they both could cause a loss of boost as well.
Both would be pretty easy to check if you're taking the snout off of the supercharger (well, it would be ridiculous to remove the belt without checking your tensioner when you're having issues - I would also check to see that all of the pulleys are properly aligned and not worn out).
The sound of tumbling rocks in the supercharger is usually the coupler though.
Good luck, and post an update on this thread if you figure out what the problem was. It's nice to have the results in case someone else is troubleshooting a similar problem in the future.
-Riggs.
-Riggs.
I have no idea about the coupler. I have a new one on order from a Pontiac guy here in the PDX area. My mechanic ordered it, and will bring it to my house when it gets here, and I will be installing it. I really shouldn't call him my mechanic, I should call him my mentor...
Whats a MAF?
