Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
yes they shake like a girl with big cans running, there are a couple of right ups on clubgp but i dont think theyre worth it, black ebay lights and HID's are the way to go
i had the same problem when i put them on a car for a friend of mine. if you can find a thick insulating tape like what you would use to seal a door were its like a layer of soft foam, make sure its thick. take out the light and put the tape on the bottomwhen you put it back together it should be more solid. if it still happens you didnt use thick enough insulation.
The lights bouncing is a common issue with the headlights. There is a write up to limit the amount of bouncing. Some people have said it works and others say it limited the bouncing. As stated weather stripping works as well. ClubGP Message Forum troubleshooting ClubGP Message Forum troubleshooting
I also wrapped some electrical tape around the long tab on the projector bracket. That helped a little.
Yep those are the write-ups I used and I have no bounce,the lights should fit without going thru all the tweeking but.....it's not too hard to fix but still.
