turbocharged406sbc
in a short deck SII block your looking at custom pistons with the wrist pin intruding on the oil ring, youd likely have to run wrist pin buttons or some other means of oil ring support.Rumor has it you can use 4.3L forged rods in the 3800![]()
5.7" vs 5.565" (for L67 comp height pistons if i recall correctly, NA rods are .1" longer)
in a tall deck SI block you can use SII pistons (NA comp height) with rebushed 440 chrysler rods (6.760 c2c) to reach a 1.98 to 1 rod/stroke ratio, and end up with the piston ~.020 out of the hole allowing for a ~.035 quench clearance (this is of course dep on OE machining tolerances aka deck to crank centerline measure's and HG thickness)
btw...yes you can put a SI crank in a SII block...you have to run a SI flexplate though...the flexplate bolt patterns are different...
