Cylinder order looking at engine?
PCweber
I did some searching and could not find this. If I am looking at the engine which is Cylinder #6? I have the famous misfire code. Also, is there a simple post or somewhere that shows the order of the coil packs and which cylinders they drive from top to bottom? I want to swap the coil packs around too and see if it helps.
Edited.Wrong link.
Be sure to check you're spark plugs for them being cracked. Otherwise you more than likley have a bad coil pack.
