gtora69
I have been a member here for awhile but I have never posted..until now and it's gonna be a good one! I hope this is in the right section.
A little information on my car. It's a 2000 GTP with modifications. As of recent I have had the blower polished, installed a SSIC and PRJ fuel rails. I put the car back together and I had the car running but I never took it for a test drive. I just had it running in the garage. I installed stainless steel braided lines and the main line from the filter up all the way to the fuel rail and on the return I ran the braided line about 1/2 way and used a compression fitting. I primed the lines.
AND THE CAR WON'T START!! I have bled the lines and dumped so much fuel on the ground that my throat was burning and the wife was hollering LOL! But the car will not start. I pulled the plug on the ICM and ran a test light over the 14 termials with the key on and cranking it over and it appears DEAD. I pulled the spark wire off, grounded it and no spark. Also I am cranking the engine over and the tach does not move.
The car only has 20,000 miles on it and I have had it since new. I have never had any trouble until now. Any help or suggestions would be appreciated very much.
Thank you
Thank you
