Rear camber~ 2008 Grand Prix
JeffW 2022
Curious as to how rear camber is adjusted on these, my rear wheels are "toed out". See attached photo below. Stock struts, exactly how is the camber set on the rear? In the attached pic, you can see them looking like top of tire is leaning inward
attachment.php
Normal.
Generally the rear have around -1 degree camber as the stock setting, I know mine are (2000 GTP). Best bet would be to
look up the stock setting for later model like yours.
Also, the more weight you have in the truck, the camber should fall more negative.
Normal.
Only weight I carry in the trunk, is my 2 toolboxes, about 30 pounds worth, the donut spare and my 1 ton floor jack
