Also here's a pretty cool article on 3800 porting.
*- Camaro Home Page Tom Henry Chevrolet
I found this way after I already ported mine but I did a lot of what they did by watching a lot of YouTube porting videos. My favorite guy is a channel called HeadBytes porting.
Gasket match and port the intake side, but do not polish.
Exhaust side you can remove all casting marks and smooth out the valve bowls. On exhaust runners Raise the ceiling a touch but do not exceed the height or the exhaust gasket. Make sure you leave the D shape in the exhaust runner though. Very important. Ive ported a dozen sets or so and guys have seen good results. Its not super hard to do, but it is pretty easy to do it wrong.
It's a waste of time unless you are going for records. You're looking at maybe a 10hp gain for the 20+ hours it takes to port them. By all means, do it if you want. But there are way better ways to pick up power than with porting heads.
Been following your build. Can't wait to see some track times. Everything looking good?
Question- I am switching over the 90# springs from the old heads to the new ones. My question is that I have ZZP stainless valves in the old one as well. Should I switch those over? I’m not sure how much of a difference if any the stainless valves would have over stock? Thanks
