Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
Didn't really make a difference. Car feels the same. I assumed it was only limiting the pcm from seeing boost According to the logs it's the same from max vacuum to atmosphere. I'll have to hit the Yard and get another 1 bar. I'm not paying 60 bucks for a new map for this test. I never had luck buying aftermarket sensors from autoparts stores anyways.
Thanks for reminding me! I had thought a few days ago about just setting everything back to stock. My first tune was made for me by a guy here. He sent me a tune before I started the engine, i just wanted a base to learn. I don't have that tune any more, or my stock file. I lost all my tunes from 4 years ago.
So I set all the tables, even spark, back to stock except for what I needed to tune MAF. Car started nice and the afr error didn't jump around. It did keep rising all the way to 180 degrees, though. But at least I have a stable platform to start experimenting now, thanks to you.
Also, my idle is closest to matching commanded than its ever been. 700 commanded, 725ish actual.
I decreased AFR : Fuel-Open Loop/Base-OL AFR : to match the scan. That should have been the first thing I did before trying to drive and log. I wonder if the stock VE table played a part. Like you said, it seems to be a mystery what they do on some cars.
Still getting lean the longer I run the car. My untrained eyes can't spot anything in the tune. I'm guessing...either a sensor is losing resistance as it gets heat soaked, or the injectors. The ECT is stable, but the wideband is seeing lean creep in the longer I drive. Wish I had a fuel pressure gauge I could use when driving. My harbor freight gauge show 63psi at idle. Fuel pump is fairly new aem e85 pump.
Another thing I am thinking. Is it Possible that the PCM is getting heatsoaked and causing issues? Stock location is in the airbox, where hot air is being pulled away. Since my box was removed, it's just sitting vertical where it was on a bracket i made. I mean, it's a computer, computers don't like too much heat, and the factory put it in the flow of cooler air. I'm gonna rig up some cooler air ducting and test.
Well I'm stumped then. If anyone wants to look, here's a new log. I left my parents home, 20 minute drive. At first I was happy, error was small. By the time I got home it was running lean. I had thought maybe my wideband was failing, giving false numbers, but i can definitely feel and hear the leanness.
I have 42lb injectors I could swap back in. Don't think they will be enough for e85, but enough to test for this issue.
I'm doing an O/L MAF tune. PE set to zero, 14.7 commanded, closed loop disabled by setting enable to 284°. Commanded still bounces around until I'm at around 24% throttle. Shouldn't make a difference I think, because I'm tuning wideband/commanded error.
i think your still trying to ve tune and dont know it. cause thats not how to tune a maf. thats how you tune VE. wb err means about nothing for maf tuning.
that seems too unconventional for me, and apparently doesn't work well if something is off. I recommend going back to using your maf sensor and o2 sensor.
He is using the MAF. This method works really well and is a lot faster than using the stock narrowband. The wideband is just slightly less accurate at lamba than the narrowband is.
Works a lot faster, lol! I've probably scanned and adjusted maf 30 times now. I know what your saying though. It most definitely should be a quick process. Russ, the guy who made the write-up, said it takes him minutes. 2-3 sub 7000hz tunes, and a wot tune.
I'll unplug my o2 tonight and see what happens. I considered it because that was his preferred method, but I'm definitely in open loop, no trims. So not sure why it would matter. Then again, I am always suspicious of the hidden tables in the PCM. Might still be some weird corrections happening with o2?
My O2 harness. I think we found our issue, lol. Gonna separate the wires, leave it unplugged and go for a drive. Would definitely explain why it gets leanner the longer it runs. Was sitting right on top of my header.
