jpatterson2881
Hey guys,
I have a 98 GTP with about 156K. I bought about 4 months ago and have put about 4500 miles on it. I drive it on the interstate 95% of the time. I've noticed that I am consuming about 3/4 - 1 full quart of oil in that time. I am not entirely sure what would cause this. I was thinking bad intake gaskets as I know these are notorious for failing. However, I am not sure if those could cause consumption. Any help would be greatly appreciated.
On top of this, IF I had to replace the intake gaskets are there any other items I would or should need to do while doing it? The guy I bought it from said the front valve cover had been updated per a GM TSB, which I did confirm. However, I have a loud engine tick/knock on acceleration. It doesn't do it while at idle. This happens even when the oil level is full. I have been told that the lifters can flatten out over time and cause a tick? I am not sure on this. I was worried it was piston slap but it definitely sounds like it is under that front valve cover. Any guidance on this issue would also be greatly appreciated.
Thank you.
Thank you.
