I haven't done much with the truck in the past week, other than finding more crap to fix. I did order the fuel filler neck, a fuel tank cap, a fuel pump block off plate, and a new parking brake cable.
The heater valve leaks, so I'll be pulling the dash off to get at the HVAC/blower assembly. I'm going to pull it all apart and clean everything, including the vent tubes and A/C evaporator and housing. Lots of tedious cleaning.
There's a busted brake line right next to the fuel tank, I'm going to just replace that 6" section for right now, get the brakes bled and test the brakes. I want to make sure that everything works before I start replacing parts. I found some R1 Concepts rotors and pads on Amazon but I'm not entirely sure they will actually fit. I will replace the rubber brake hoses after I know there aren't any other leaks.
I've got to finish mounting the electric fuel pump, wire it up with a relay, and replace the rubber fuel line in the engine compartment. Then I can put some gas in the tank and flush the hard line going up to the engine compartment, catch whatever comes out in a water bottle or something clear and watch until it's clean gas throughout the fuel lines. Then I'll be able to prime the entire system and make sure there are no leaks anywhere. After that, all that's left is to install the block off plate, top off the oil, shove the muffler onto the end of the header collector and start the truck. It's still going to take forever for me to actually get all of this done, but at least I won't be waiting on parts.
There's still more that I have to fix before I can drive the truck... I've got to get an actual exhaust on the truck, replace the front shocks, bolt the bed and rear bumper back on, change the gear oil in the front and rear axles, grease every joint that has a grease nipple, and take the truck over to the coin op car wash and pressure wash the ever living **** out of it. After it's clean I can take it over to the Auto Skills Center and plate/reinforce the frame, weld in the patches I will be making for the floor and the new rocker panels, fog everything with rattle can black and call it good.
There's still a lot more that I want to do, but once I'm driving the truck I can space out the rest of it.
