Ahh, West Springfield..hm. A good 1.5-2hrs away from me haha. Don't know if that would be doable for me unfortunately... Anyways I also thought the heat shield touching the boot would be a problem, though if any you'd think it would be specific to that once cylinder (and I only once got a code on the highway for random/multiple cylinder). I guess I can try running him without the individual shields for the wire boots, though I'm a bit concerned in the long run how that would affect them since imo they must come with those for a reason.
So... a hose clamp around one of the pipes on the manifold going through the heat shield is what you're suggesting? I'll see if I can manage that haha. Is there a specific size hose clamp I should be looking for then to use?
As for the plugs, I have not swapped them out yet but I did purchase a new set of NGK's, the TR55 I believe. Just waiting on a good day/chance to work on those - even though my dad keeps insisting I shouldn't change them because the ones in the engine now are still new. Well yeah, but if the problem started happening after putting those in then I'm afraid it must be that Pumpkin does not like Bosch lol. Those came pre-gapped at .060, but I don't know yet if all of them are still properly gapped (I checked one and it looked fine, but not all) - I did wonder if the mechanic changed the gap on them or something.
And as for the wires, I did not swap them - only the coils. My guess is the coils themselves aren't bad as the MSD's are still in the 06 and my dad hasn't had any problems yet either - but it could be the wires...or the combination. Like I (might've?) said, I don't know how long those last provided no mechanic has yanked on them like a brute like they have to my mom's Bonnie, but from the service and part purchase records the previous owners gave me, it looks like they bought these coils and wires early 2010.
Ah, Pumpkin, the list with you doesn't seem to be getting any shorter. I got the trans fluid and filter changed recently because the fluid was yellow and if driven enough the temp was getting to the low 200's, also slipping for a split second if accelerating from a stop (not necessarily flooring it either) - here hoping that would help take care of that for a while so I could focus on this darned misfire and a few other things, but nah...the trans still gets hot and I even noticed today if its around the 194-206 temp range it gets to, it gets difficult to shift from park to drive. Please staahp Pumpkin I can't keep up with so many things x.x
Not to mention the coolant leak that I have a feeling is the water pump and/or those elbows...
Anyway I was reading the other day someone else's thread on what turned out to be an exhaust leak at the flex pipe area of their downpipe, and the sound they were describing their engine made when accelerating sounds a lot like what my car is doing (like a plastic bag flapping while caught on something), except I do notice the loss in power (and the RPM's do dip before eventually jumping back up), and the car does have a brand new downpipe/cat that was installed a while after these seemingly cursed spark plugs were put in. *head scritches*
