    TIPS:
Custom turbo kit. S369sxe/3.5"dp/Holden setup
kawasaki22106
**active partout**All prices are negotiable to a point but I will not accept low ball offers. Don't like the price and think im way off target I'll be glad to discuss in a pm.
Part out list:
Whole turbo setup: $3450 kit includes: kit has 2k miles on it.
Hot side only turbo kit: includes turbo, all piping, both wastegates $2800
-holden intake manifold w/ pcv blocked, map sensor, and a bung for a boost gauge. $350
-92mm TB $125
-LS3 maf $70
-borg Warner s369sxe twin scroll 1.10ar divided $950
-2 precision 46mm wastegates $275 each
*Hot side piping* $2000
(Everything is v band)
-dump tubes
-crossover
-cartuning turbo manifolds
-3.5" downpipe with cutout
-cooling mist water meth with 2 nozzles $300
-treadstone tr1245 a2a intercooler $350
-cartuning bov $100
-manual boost controller $20
For sale not with the kit:
-mezeire flex plate with arp bolts $325
-17" American racing wheels nitto 555 on back mickey Thompson ET street on front $400
-self tinted tail lights $75
*Parts below are sold*
-Block bored out .020, Arp fasteners with clevite bearings, 8.5:1 compression with hypertunetic pistons, L67 crank and rods, balance shaft delete with oil passage drilled and tapped $500 sold!
-L36 heads ported with oversized Manley valves and 150# springs $800 sold!
-Yella Terra 1.6 roller rockers with bolts and pushrods $350 sold!
-st5 turbo cam $200 sold!
-roll master double roller with chamfer cut $100 sold!
-mls head gaskets used once $100 sold!
-arp head studs $50 sold!
-voltage booster $10 sold!
-aem boost/vac $100 sold!
-aem fuel pressure $100 sold
-dual aeroforce scan gauges in blue $200 sold!
-walbro 485 pump in a canister $200 sold!
-racetronix fp rewire $50 sold!
-80lb injectors $200 sold!
-air ride suspension: $3200 air bag it kit includes: sold!
5gal tank, 2 compressors, smart ride management for pressure and height with presets, 4 struts, all 3/8" air line, water trap, all valves, solenoids, wiring. It is a bolt on kit.
-bmr front (blue) and back (black) stb $250 sold!
-black bmr lateral arms $350 sold!
-black bmr trailing arms $100 sold!
-gmpp front and rear sway bars $100 sold!
-custom cowl hood little damage on underside $600 sold!
-netami seats with 5 point harnesses $200 sold!
-super cooler trans cooler $50 sold!
-mezeire ewp $250 sold!
-black housing head lights $150 sold!
-6an fuel and return lines $75 sold
-catch can $25 sold
-roof rails $150 sold!
-polished dog bones with intense poly bushings $100 sold!
-poly bushings installed in mounts on rad support $25 sold!
-poly engine mount $100 sold!
-poly trans mount $50 sold!
-gmr trans $6500. SOLD!!!
If any parts are purchased and I find damaged when removing a full refund would be issued since I won't know about engine components until it's apart. All parts are sold used and in as is condition.
Re: Gmr trans, Holden/ custom turbo kit
Wish I had $ burning a hole in my pocket!
GLWS
What'd you run with that setup?
