Re: My 1984 K10 - Daily driver
So I broke down the RPO codes on the donor truck. I like to nerd out on minutia. The things that stood out to me were;
7200 Lb GVW
Positrac LSD
130 amp alternator
HD trans cooler
High capacity air cleaner
Reese type trailer hitch
The suspension/towing stuff should help with the resale value of the roller. Even though the seats are trashed, I'm tempted to grab them for the K10. They feel very nice. I will be measuring for fitment for sure. I'f I can find a cheap set of steelies for the Yukon, I'll snag the alloy wheels too. They should fit the K10? I'll research that...
Here's the full list:
AG1 : ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AG2 : ADJUSTER, PASS ST POWER, 6 WAY, SPLIT BENCH
AJ1 : WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS
AL4 : SEAT RR, BKT
AS3 : SEAT, RR, SUBURBAN
AU0 : LOCK CONTROL, REMOTE ENTRY – KEYLESS ENTRY (DOMESTIC)
AXP : VIN IDENT POSITION, MULTI- PURPOSE VEHICLE
A31 : WINDOW, POWER OPERATED, ALL DOORS
A95 : SEAT, FRT BUCKET, HIGH BACK, PASS & DRIVER RECL
BVE : STEPS RUNNINGBOARD, SIDE
B30 : COVERING, FLOOR CARPET
B39 : COVERING, FLOOR CARPET, LOAD FLOOR
B58 : COVERING, FLOOR MATS, FRT & RR, CARPETED INSERT
B85 : ORNAMENTATION, EXTR MLDG BELT REVEAL
C36 : HEATER, AUXILIARY
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C5Z : GVW RATING, 7200 LBS
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C69 : HVAC SYSTEM, RR, AIR CONDITIONER
DF5 : MIRROR I/S, R/V, LT SENSITIVE, COMPASS, O/S TEMP
DH2 : MIRROR, I/S FRONT VAN, LH AND RH, ILLUMINATION WITH DUAL SUNSHADE
DK2 : MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, PAINTED
DK7 : CONSOLE ROOF, INTERIOR, CUSTOM
D07 : CONSOLE, FRT COMPARTMENT FLOOR, CUSTOM
EVA : TEST DVT, EVAP EMISSION REQUIREMENT
FE9 : CERTIFICATION, EMISSION, FEDERAL
FF6 : ARM, LH, TORSION BAR SPRING ADJ (E)
FF7 : ARM, RH, TORSION BAR SPRING ADJ (F)
GT4 : AXLE REAR, 3.73 RATIO (DUP WITH 5 X 1)
G65 : LEVEL CONTROL MAN, SELF-ADJUSTING
G80 : AXLE POSITRACTION, LIMITED SLIP
JAN : PLANT CODE - JANESVILLE, WI, BOC
JC5 : BRAKE, VAC POWER, 4-WHEEL DISC, 7200 LBS
KG8 : GENERATOR, 130 AMP
KNP : COOLING SYSTEM TRANS, HD
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K47 : AIR CLEANER HIGH CAPACITY
LM7 : ENGINE, GAS, 8 CYL, 5.3L, MFI, IRON, GM
M30 : TRANSMISSION, AUTO 4 SPD, HMD, 4L60E, ELECTRONIC
NF2 : EMISSION SYSTEM, FEDERAL, TIER 1
NP5 : STEERING WHEEL, LEATHER WRAPPED
NP8 : TRANSFER CASE – (ACTIVE) – PUSH BUTTON CONTROL, 2 SPD
NZZ : SKID PLATE OFF-ROAD
PF4 : WHEEL, 16 X 7, CAST - ALUMINUM
QMK : TIRE ALL P265/70R16 WOL R/PE ST TL
SLM : STOCK ORDER, PROCESSING CODE
TFE : SALES INCENTIVE COMMITMENT PLUS
T96 : FOG LAMPS - FRONT
UP0 : RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, AUTO TONE, CLOCK, ETR.
UQ3 : SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO
UY7 : WIRING HARNESS, TRUCK TRAILER HD
VB3 : BUMPER, RR, STEP, CHROME, IMPACT STRIP
VR4 : TRAILER HITCH, WEIGHT DISTRIBUTING PLATFORM
VXS : VEHICLE COMPLETE
V22 : GRILL RADIATOR, CHROME
V54 : LUGGAGE CARRIER, ROOF, PAINTED
V73 : VEHICLE STATEMENT, USA/CANADA
XMK : TIRE FRONT P265/70R16 WOL R/PE ST TL AL2 111S
YD3 : FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING, GVW PLATE
YD6 : REAR SPRING, BASE EQUIPMENT
YE9 : CONVENIENCE PACKAGE, COMFORT & DECOR LEVEL #3
YMK : TIRE REAR P265/70R16 WOL R/PE ST TL AL2 111S
ZMK : TIRE SPARE P265/70R16 WOL R/PE ST TL AL2 111S
ZW7 : CHASSIS PACKAGE,PREMIUM SMOOTH RIDE
ZW9 : BASE BODY AND CHASSIS
ZY1 : COLOR COMBINATION, SOLID
Z82 : TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.0.
Z88 : CONVERSION, NAME PLT GMC
1SC : OPTION PACKAGE 03
1SZ : UNT OPTION PACKAGE
41U : PRIMARY COLOR, EXTERIOR, BLACK
6XL : COMPONENT FRT LH COMPUTER SEL SUSP
7XL : COMPONENT FRT RH COMPUTER SEL SUSP
92I : INTERIOR TRIM SHALE/PEWTER
922 : LEATHER, MED DK PEWTER II/VERY DK PEWTER
