PWNED
I have been going in circles with this issue of my LTFT hitting +16 at times. Other times it is perfectly fine. I have sprayed brake clean and poured water on every vacuum line, gasket or rtv seal and trims will not change (usually -3-10 ltft at idle) Yes its rich but whatever. I even replaced my #1 o2 sensor with a genuine GM part. I have also replaced my BBV due to the findings of the orange diaphragm having a minor tear with no change. I have never kept an eye on my trims this much since my IC install at the beginning of this month. I want to say that I have watched my wideband dip into the 11's/12s (cruise/part throttle/idle) before my IC install so I believe this is an issue that has been on going. The car has no real issues with pulls. It does pull decent for what it is with no hesitation ever. At idle my fuel pressure is 45psi. At 2500 rpm it is at 44. When I got wot it will hit 62. Prime is 54 and will drop to 40 and rise back to 48. I have not tested fuel pressure when my issue happens due to the fact it is sporadic.
Some screen shots but the actual logs are linked here to the hpt forum.
http://www.hptuners.com/forum/showt...ther-times-perfectly-fine&p=383568#post383568
