jetfighterv
okay i will when i get home from school
okay lol yea ive always loved cars but never had that dad figure so I never got to do anything with cars till about a year ago when I bought my fiero and rebuilt the motor and pulled it by myself
Man. I've always wanted a fiero! Can't wait to see a thread on that!
And yup. My grandfather was a mechanic, but he died before I was around so I'm with you there! My dad's into carpentry, which is cool, but no so useful on cars. Haha
my dad was no help to me working on cars. i recall the day he came home and i had the engine pulled from his old work truck, all he said was that had best run and drive again as he walked by.
for real tho, we all got it easy today. i had to go to the library and take out chilton manuals. theres was no internet or forums or google to ask lol
time to maybe pop the old injectors back in. or test the fuel pressure with a gauge, you need over 43 psi.
that would be a bad fuel pump causing the low pressure, would explain why it was cranking 10 times before it fired up the before vid you posted.
try beating on the bottom of the gas tank, see if the pressure goes up. if it does and then fires right up, you know the pump is bad. beating on the tank can shock it back to life. but its a temp fix at best.
Well, it's a start! (no pun intended). Go ahead and rent or buy that fuel pressure tester and see what the pressure is. If it's just low and below 43, test the fuel pump for voltage and ground at the pump connector, if no pressure, then still test the connector for voltage. That way you can be sure you're actually replacing the issue and not parts swapping for no reason. There's a fuel pump resistor that can cause these symptoms. Just follow the steps
does auto and advanced auto not have fuel pressure gaug loaner tools anymore?
Ones out here do. Might have to call ahead to see if they're out on rental
