jetfighterv
So I have just installed new injectors and fuel rail on my 01 gtp now nomatter what it will not start before it ran fine everything is hooked up ive checked twice
is everything oem or aftermarket?
the fpr on the new rail might not be good.
if you got fuel it should at least try to start. if the vac line off it has gas in it, or smells of gas the fpr is bad.
what are these new injectors? stock replacements?
check for spark yet?
side note, the injector harness can have a bad spot that you aggravated by taking the plugs off. so you can look for a break, or also test the power at the plug, test light works, or you can take a marker light out the head light and push it in the injector plug. you turn the key to run and the bulb should flash a few times, or the test light will flash if its got power. it only flashes a few times then you have to re cycle the key, its the prime for the engine to start. if it dont flash at all you got no power to them.
Do you still have the old FPR off the old rail? Swap?
Most are a circlip. Get the clip out.. wiggle..wiggle...wiggle and it's out. Lube the o-ring before you put into the new one
Yea that's what I was trying I think I'm not getting a good seal on one injector I can spin itIf you step on the gas while starting with a bad FPR sometimes it will start.
I kinda doubt it's an fpr though
What or where is thatwhat's the pressure at the rail key on engine off?
