^^Just use a 100amp in-line stereo fuse ?? they are pretty cheap
"I fill my tank up until it will take no more. As a result I have very accurate fuel mileage history"........ I've always been told this a bad thing to do. I used to do it all the time and a friend of mine's husband said I shouldn't do it cuz it will cause problems.
Going off-topic a bit, but I have a question..... I've noticed when my gas hand get to the 1/4 mark it will start "floating" so to speak when accelerating. Is this normal? Should I have it looked at? I might have a quarter tank, but the gas hand will move up to almost 3/4's.
With regards to topping off, I would agree that the EVAP system probably doesnt like getting fuel in it but you'd be kinda hard pressed to do that and there is some type of overflow/fill drain hose on the tank I believe. As well Ive been doing this for years. My last Grand Prix I owned for probably 6 years, had nearly 200k on it when I sold it and it was still running strong then and I always filled the tank up on it until it could not hold another drop. And Ive done the same thing with every car since including my current GP.
when doing the Alt rewire. DO you have to take the old wire from the fuse-block that wraps around engine and back to alt off. or do you just add the one from fuse-block to alternater
Leave it on. Electricity takes the shortest/easiest path, so it will use the re-wire. Yes, there were be a few electrons that will want to take the long way, but the work involved in taking it out isn't worth the trouble. I left mine in place on both cars.
