I thought the SSCs are lowering springs, causing an issue with the angle or interference of the axles. Doesn't this require me to shim up the engine/trans assembly to restore the correct axle angle? Just going by what I read here, I'm not a W-body expert by any stretch.
Did you grab the Bilsteins, the auction is over. I have not read anything about needing to shim the motor mount for lowering springs and have not found the need to do so with the Vogtlands. It would make sense if you were lowering the car so much that the driveline angle was waaay off, but the CVs on the axles can run at different angles with slight lowering.
Just looked up prices on Rock Auto and looks like the OEM are same price as KYB. Last time I bought the KYBs they were like $75 each. For the same money I would get the OEMs. R
I did buy the used Bilsteins, will report back on the results in less than two weeks if all goes well. Apparently @spazzz ran the SSC lowering springs for a while, then shimmed up the engine and trans. One can only assume he had a reason for doing so. For this car and the way it will be used, I'm not willing to entertain lowering.
That was/is on FE3 struts. The Bilsteins won't drop as much. You might not even need the spacers with the SSCs.
You are going to be very pleased with the Bilsteins.
What is the concern, axles rubbing the body? Bottoming out in the transmission?
Edit: If I stick with the lowering springs, do these cars usually need some sort of camber adjustment kit?
A little wobble from take off from the axles but nothing detrimental. No major issues with lowering.
Some guys don't even bother with spacers.
I'm on SSC's and half the spacers (half the thickness) installed; been vibrating for 5 years now.
Pssst, it's in the title. :th_biggrin2:What year is your car?
What year is your car? My 98 gtp sedan has oem regal springs and gxp bilsteins on it and I still think the struts are a bit harsh. I wish they still offered the comfort bilsteins. Do you find the ride harsh on yours? I suppose California doesnt have crap roads everywhere, thats probably more of my problem. The car feels really good on the highway but low speeds around town are really annoying on bad roads.
