Hysterione
I have read else where that you can just throw 42# injectors on and not need a tune to run e85? Never tried it though.
I'd recommend exhaust work on ANY 3800...of any level of modding.
It's god awful. The catback is fine; but everything else needs help. Manifold casting is crap, the downpipe is tiny, and the U-Bend is even worse.
On a stock car, PEM's and a 3" downpipe would probably add 15-20~ horse...and most of that would just be killing all the KR.
I had similar KR on my car, bone stock except shift kit. ZZP plogs + their 3" dp dropped it down to < 2'. The 180 thermostat didn't really seem to help KR on my car nor did 1 range colder plugs. I'm considering getting their 1.9 rockers today since they're on sale to try to eliminate KR entirely, but not sure if it's worth it.
you can still run headers or a downpipe with a catalytic converter and keep all the emissions intact. are you sure Utah county checks for emissions like that? I would be interested to see how their check can actually see if emissions have been tampered with. Even if you get a tuner and tune the vehicle, there are still gains to be had if you keep the emissions.
A cheap hi flow cat or a "test pipe" is the way to go if your e testing is an OBD2 check and visual inspection for the cat, a quality hi flow converter is only needed if you need to pass a sniffer test. I had to install a good magna flow HM (high metal content) on my gtp to pass the sniffer before OBD2 check only came in to effect in my area, a universal or cheap hi flow just won't get the job done compared to a stock cat.I know at least one person that runs SD headers and lives in SLC, not sure if he is catless or not, but I would suspect that he does have a catalytic converter, so either he deleted the codes or his catalytic converter works good enough.
