All kinds of things. Most commonly is no HVAC and no auto on lights. You can replace the ignition switch, or do this "ignition saver mod":What problems all happen with the ignition switch going bad?
No problem. I bought a new ignition switch a few years ago, with the plans of changing it. When I did, I found that all my aftermarket alarm wiring was tapped into the switch wiring, so I changed plans and just did the mod. Been almost 3 years and it is working just fine, so it is a viable option.I will definitely give that mod a good look to see if I should do that. And thank you for the schematics also.
