Need to Buy a Hub, Which Brand?
born2pdl
My 04 GTP has all the brake warnings, bad LF wheel speed sensor. Rockauto has these brands. Should I stay away from any?
Centric, GMB, WJB, Mevotech are cheaper but are they any good?
I recognize Raybestos, Timkin, ACDelco, SKF but price goes up.
Which one would you get?
add moog to the good list and get one of those, they all got a 3 year warranty and do go bad. but not as fast as the cheapos.
Timkin or SKF. The Timken is only $85.79 and if you search you can probably find a discount code which may drop it a bit more. I run only Timken or SKF bearings in my GP and they have never let me down. Just make sure you torque the hub nut to the proper setting and you're good to go.
*edit* Forgot about the Moog's. Those are good quality as well. Another option if they are the most affordable.
I go with timken for years, didn’t like the moog hubs when I used them, didn’t last long for me. Never had a problem with timken
I’d honestly go with GM ACDelco. I try and keep non go fast parts OE replacement parts.
Do not do mevotech anything. I've had issues with all their parts. GMB is decent but wont last. Moog or Timken is the best I've used
Ive heard that timeken and SKF can be expected to go for a long while.
Moog are ok. Last about their warranty period.
The others die quick and are not worth the money.
Sent from my SM-G920P using Tapatalk
I have good luck with used low mileage OEM. The bad news is low mileage stuff is becoming hard to locate any more. Good news is you can use a hub off an Impala all the way up to 2014 model year I believe. I picked one off an 09 Impala at a local pick n pull for $15.00.
They all suck. I've had my car for 8 years now and had to replace the front bearings 7 times (4 on the right front, 3 on the left front). I started using SKF, but have switched to Delco because up here, the Delco has a 5 year warranty.
