Yes, its common. I have seen many including mine with silicon around that antenna. Nice looking ride!
coming along nicely. surprised the LIM gasket change didn't fix the misfire as sometimes a leaky/bad LIM gasket would cause the misfire due to coolant getting burnt off.
I would try some different plugs myself, 104 al is a pretty cold plug being your pretty much stock other than the 3" DP as far as flow mods go. A colder plug is more apt to create more misfires when not needed. What part of Ontario are you from if you don't mind me asking?
Yeah might not hurt giving the 605's a try for what it's worth. I'm about 45 mins SW of London on the 402,been around the grey county area quite a bit though as I had relatives that just moved from Owen Sound back down this way not to long ago. Nice clean looking GTP you got there, I don't see many white comp g cars.I actually just very recently went to the 104's from NGK TR55IX's. I was aware it was too cold at the time but it was a recommendation from John at INTENSE performance when I got my tune and told him the amount of KR I was having. The misfire however, has been around since the day I picked the car up when it (seemingly) had factory spark plugs. Back then, it was bad enough to set off a check engine light anytime you idled for more than a minute or two.
I would switch back to my TR55IX plugs, but one broke during the swap, and I've found a bit of a performance improvement out of the copper 104's. Maybe I'll give 605's a try though, at a buck a piece it doesn't hurt to experiment.
I'm from Grey County, couple hours NW of Torontoyourself?
Nice...
I'm actually working near Petrolia right now!
Winter is coming...
