Negative clamp nut size for 2005 Pontiac Grand Prix - 3800 Series 3
Hotsuma9
I lost the nut that goes on the bolt for the negative clamp. I just need to know what size the nut is so I can get some more and have some to spare. Does anyone know?
if you dropped it down by the belts its in the motor mount bucket. either lift the shield and paw around for it, or drop magnet on a stick down there and fish for it. every last thing i drop down there ends up next to the motor mount.
Yeah. I shouldn't have taken it all the way off. It dropped down right below where the battery sits. It's under there and I haven't had any luck fishing it out.
Update to this issue. The nut size for that funking looking clamp is M6. I went into my local hardware store and picked up a couple for a few bucks.
It wont. You find out when the battery is dead.
I put a washer under mine when I first did a HID kit, battery fizzled from a loose connection.
The bevel rides the notch and pulls the clamp together when tightened, without the bevel it doesn't do $hit.
Jeepers Hots, it took me awhile to find the nuts.
Afckin squirrel couldn't have done better.
You should really hop off yer Ducati and order from that link.
