Thought I was ready to start the engine last night but got snagged by some petty shyt. Things that needed to be done tho. Connected the RaceTronix fuel pump wire to its standalone fuse under the hood. I had to cut the wire so it would cleanly pass through the passenger side grommet. I routed the wire through the inside of the car rather than the outside. Did a simple oil filter change. Drained the old oil. But forgot the jug of new oil and home, DOH!
One of the things that annoys me to no end is the coolant overflow tank. Finally got it sitting pretty good with like 1in. of clearance between the pulleys. Had to do some hacking and drilling and zip-tie’ing. Pics below.
Fuel pump wire with shrink tubbing:
Drained oil. New filter:
“Well Sir, that’s your problem right there, ya see. And that tubing right there… it’s discontinued. But I still know a guy that makes ‘em. That will be $200”…. Found my vac. leak!
The coolant bottle was rubbing up against the pulleys and that just couldn’t be. So that bottom tooth got hacked off. Whatever that tooth clipped into is long gone on my car:
Then drilled a hole in that neck area there, passed a sip-tie through it. Using 3 zips total, I connected it so the fender wall. Jeeze. What bullshyt. Who designed this F’in thing?
Moved the mounting holes on the tank and fuse box over like .5inch:
Got me a good inch of clearance now. And tank rests firmly on the strut tower:
Mystery connector. Anyone have any idea what this connects to? It got EATEN alive:
