Scottydoggs
Killa Bee
http://www.grandprixforums.net/threads/106488-Here-is-a-way-to-stick-it-to-Photobucket we found a fix for photo buckets bull sh1t.
and best way is to drop the rear of the sub frame 2-3 inches, then unbolt the bushing caps and spin the bar out. sadly this time you need to use the rockers to hold it up, the put a jack under the middle rear fot the frame and just lift it till its touching, then back the bolts out as far as they will go before coming out, then lower the jack to the bolts but not hanging on them.
you want a dorman 33 mm solid bar, they run anywhere from 65 to 140 on line shipped, you'll need to search around for the cheapest one.
pic of the frame dropped. rack is removed why its 6 inches low. you cant go that far with out breaking the steering shaft from the rack to the column.
