mtbuicknut
I had these 4 codes show up car went into reduced power, was able to clear the codes and go on but now no dice. Changed TB and no luck, then pedal and no luck. I two wires at the pedal that have 5 volts unblocked but when attached voltage was no longer the same. I cant find any wiring diagrams so that I can chase it back. Found one set of grounds below the air cleaner on the block. It must be a bad connection but not sure where to start. Any help would be awesome.
Thanks Rick
Thanks Rick
