2006 Grand Prix Timing chain scraping on front cover
ttedesco
As the title says the timing chain is scraping on the front cover. We've changed the timing chain and gear and put on a ZZP Double thick gasket and it still scrapes. When we tore it apart to change the timing chain gasket because it was leaking it didn't scrape so I have no idea why it is now scraping, the noise isn't coming from anything belt related either, What could it be scraping on? I'm clueless.
Are you sure you got the timing chain/gear set pushed all the way onto the camshaft and crankshaft? That's the only thing I can think of.
I don't really know what else to tell you. There is a ton of room in there so it should never even be close to touching. Something has to be installed incorrectly.
