    TIPS:
TEP Trans and some turbo stuff
sillyballs23
I think I'm going to go in a completely different direction with my car so that means a small part out. After I try to figure out how to get pictures on here I will.
Things For Sale:
Stage 4 TEP trans. Has the groove less input shaft with a Precision Tq converter with a 3000 stall. Hasn't seen oil. Brand New 3000$ Still has a warrenty. Trans is out of an 01 Regal
ZZP Front and rear turbo headers. Both new. Never installed. Never mocked up. 300 for both or 150 each. SOLD
I have a Borg Warner s366. Brand new Never bolted up. If you look at it like the way precision markets their turbos its a 6674. T4 divided housing with a .91AR. 600$
I have a manual boost controller and an oil feed and return line kit. Both are from ZZP and brand new. 150 for both or 75 each. SOLD
Ported gen 3 lim from intense. Made to match stage 3 heads. 140 obo. Would be good for someone with a areoforce scan gauge. Already has the extra air intake temp sensor for the gauge drilled and tapped.
EV1 to EV6 injector adapters 15 bucks
Lokar flexible trans dipstick. Commonly used for the SD headers. 48" long. I put thinker o-rings on it to help it seal better. Never leaked. 40 bucks
Upstream O2 sensor. has 3 weeks of run time on it. 20 bucks
Innovate MTX-L wideband. Has a new sensor. Comes with a bung. 9 ft of total cable. Gauge works great. 100$ SOLD
80# injectors with ev1 to ev6 adapters. 210 shipped
Everything I have for a gen v/l26 to n* adapter, throttle and cruise bracket, lq4 maf and pig tail from zzp for a series 2. n* adapter is drilled and tapped for water meth nozzle. 150 shipped
intense stage 3 heads with 165# valve springs with titanium retainers. 1500 local
zzp sattama st5 cam brand new. 275
comp oer lifters. brand new. 125
Comp cams Roller rockers with push rods. 1.73 ratio. 230 shipped
I have way more to list. would also entertain package deals.
