97AutoXVette
Asking Price: $5200
Mileage: 145k
2002 Grand Prix GTP Sedan, built and tuned on E85 including recent air-to-water intercooler installation. Over $5k in modifications since April 2016.
Very meticulously maintained. ICE COLD AC. The interior is in excellent condition in this car. Tires have great tread. Strut towers are rust free. I have the title in hand, free and clear. I bought this car 100% stock and personally added all the mods below. I can tune the car back to pump gas as well if you'd like!
Link to my Craigslist add since I can't get pics to upload now with the latest changes to photobucket:
https://cincinnati.craigslist.org/cto/d/2002-pontiac-grand-prix-gtp/6285502379.html
Mod List:
- ZZP F-Body Brakes Setup (SS brake lines, 12" drilled/slotted rotors, dual piston aluminum calipers, power-stop pads) ($510)
- ZZP Full-Stack Air-to-Water Intercooler Kit ($940)
- Aeroforce Interceptor Scan Gauge ($230)
- AEM Wideband ($170)
- ZZP Front Strut Tower Bar ($100)
- ZZP Rear Strut Tower ($90)
- ZZP modified Fuel Rails ($250)
- ZZP Fully ported & polished Gen3 supercharger (inlet and outlet including "H-bar" removal). EGR port welded and blended. ($400)
- ZZP stage 2 ported Throttle Body. No longer available from ZZP ($375)
- ZZP 160F Thermostat ($10)
- ZZP Aluminum Coolant Elbows ($10)
- Yella Terra 1.8 full roller rocker arms ($375)
- ZZP 3" Downpipe ($150)
- ZZP front Powerlog manifold ($200)
- ZZP modular pulley system with 2.8" pulley ($100)
- 9" ZZP Air filter ($60)
- ZZP Ignition Coil Packs ($100)
- ZZP Ignition Control Module ($100)
- Autolite 606 Iridium Plugs ($40)
- New Plug Wires ($50)
- ZZP Poly Motor Mounts ($60)
- Deka #60lb injectors ($250)
- Caspers fuel pump rewire harness ($50)
- ZZP alternator power cable ($20)
- HP-Tuners Pro Tune (I have ran the car on both pump gas and E85) (cost me $650)
- Underdrive water pump pulley ($60)
- 923 accessory belt for underdrive pulley setup ($30)
- EGR and evap delete, MAP relocation with all new vacuum lines
Asking Price: $5200
Mileage: 145k
Mod List:
