khornocker
Hello, I just started having an issue with the vacuum line under the supercharger snout popping off under hard acceleration.
it happened this morning, I had to slow down to about 15 or 20 mph for the car in front of me to turn off the road, I then got on the gas pretty hard and about a second or two later the car hesitated pretty hard then the engine stopped. the CEL came on with a p0068 code (reduced engine power). I opened the hood and sure enough the vacuum line had came off. This also happen two days ago in the same situation.
Ant thoughts?
I think the traction control might have activated right before this happened causing the hesitation and surge.
My car is a 2005 comp g with a 3.4 pulley and stock everything else.
Ant thoughts?
