Went to rotate my tires, noticed oil pooling in the motor mount bracket. Looked under and at first thought an oil pan bolt was missing, then noticed the stud wedged in the hole so it must have snapped off. I replaced the oil pan gasket a few months ago, so I did quite a bit of research beforehand. Someone on this forum mentioned the torque spec to be 12-13 ft-lbs for these bolts so that's what I used. Looked it up in the factory service manual and its actually supposed to be about 10 ft-lbs, so my only assumption is that one of the bolts (being over-torqued) simply became too stressed and broke off. I had used information from the forum before when doing my lower intake manifold gaskets; in more than one case I read that people used a torque spec. a little higher for the manifold bolts than the factory one. That repair went without a hitch so I figured what the heck, it won't hurt anything. Lesson learned don't listen to ding-dongs on the internet with regard to torque specifications.
Anyway, someone correct me if I'm wrong but some of the oil pan bolts (the ones located where the pan dips up into the motor mount bracket) actually thread into the bottom of the timing cover? Pretty sure the broken one is one of these bolts. I'm thinking the best way to approach this is take the timing cover off to get that stud out. That makes more sense to me than taking out the oil pan again (pain in the butt), plus I can replace the timing cover gasket while I'm at it which would be something that might have to happen down the road anyway. I've never had to remove a broken stud before, so that will be a new learning experience. I really don't know how difficult that might be since these are such tiny bolts. So any suggestions on this predicament?
