    TIPS:
FS : KYGTP Belt wrap kits back!
Recently installed black bar...
Here is better anyway, maybe that's why you guys are logged on here all day instead of the Regal forum.
Hey it is what it is, we're here to help each other out and talk 3800..........Would it work with ZZP modified fuel rails or fuel logs are a must?
Really, y not?
Smoothflow pulley wrap looks ok but it doesn't have that opening for intercooler lines like this one has. So i prefer this one plus it looks better, but damn it wont work with my ZZP full IC?
Only reason it doesn't work with factory rails is where the FPR is located. It hits the bar. If you have modified stockers that move the FPR off somewhere else, it can work.
Some have just ground down on the bar itself to clear the FPR on the stocker rails. Not a huge fan of that :)
People have also used this without an intercooler. What they do is put in spacers under the bar it self it raise it up some, where the 3 bolts go in to.
Then put some spacers under the ICM bracket to make the belt clear it.
Example where bar was used on a modified HBody bracket setup. He used a different pulley to get his desired effect. But can see the spacers under the bar if look closely.
I wish I could include spacers, but it seems there is quite a few sizes needed... no IC... short stack IC, one of the 10 other brands out there sizes ....
I have the ZZP full IC and ZZP modified fuel rails, will this belt wrap work?
yes this works with the ZZP full size IC and rails.
It was originally designed for a car that had a ZZP full size IC.
Rails of any kind should be fine. Only issue was stock fule rails, the stock FPR would hit the bar.
an intercooler is not 100% needed, you just have to do some homework to get it on there, shorter bolts, and get crafty with spacers
under the bar and ICM.
The intercooler doesn't block any install of the bar... People have used no ic, zzp ic of all sizes, intense, tep, ect... the only thing is just the height of the IC and getting the belt geometry correct... which is why I mention spacer usages depending on your setup.
Since the 2.25" is most popular IC size this is the bolt size I include. I couldn't buy every single bolt size there is as they are stainless and not all that cheap... And I have no idea ahead of time
what sizes people all want for all the different options available. If anyone wondered
