Misfire only at idle on #2
sugaryuk
After L32 swap into my GT, I'm getting a crap load of misfires only on #2 and only at idle. I get up to 200 misfires (using aeroforce gauge) while idling and once under load while driving misfires go to 0 and misfires return when back to idle. When motor is warm--it still happens, but amount of misfires appear to go down. Swapped out plug (looked fine-not wet), wire, coil and injector-- no help. Vacuum is steady at 19-20, motor has about 50 k on it and didn't do this before swap--but motor sat for about 4 months (may-sept) in donor car. Took it out on hwy for over an hour-running the piss out of it hoping to get it hot enough to cure it--no luck. So question is...why only at idle? Would a valve issue not misfire all the time? Could a pitted cam lobe cause this? Head gasket? Any ideas out there?
Start with the basics:
Possible causes
- Faulty spark plug 2
- Clogged or faulty fuel injector 2
- Faulty ignition coil 2
- Fuel injector 2 harness is open or shorted
- Fuel injector 2 circuit poor electrical connection
- Ignition coil 2 harness is open or shorted
- Ignition coil 2 circuit poor electrical connection
- Insufficient cylinder 2 compression
- Incorrect fuel pressure
- Intake air leak
and make sure your MAF is good.
Possible causes
- Intake air leak
Like I said, I've already swapped out all the parts with known good parts and I've checked the connections- they appear to be clean and making good contact. I can't hear or find any leaks. One thing I forgot to mention is that when I started it up for first time since install, after a minute or 2 engine started making somewhat loud ticking noises. (didn't have oil gauge hooked up yet--dumb move) so I shut it off and checked dip stick-- didn't look like oil hadn't moved much so I banged on oil pump housing thinking that spring might of been stuck after sitting for a while. Restarted it and noise went away and now dip stick was wet. Engine appeared to run fine after that-- no noise or smoke. After gauge install, pressure is 60 at load and about 45 idle--seems good. So possible temporary oil starvation causing damage to cam lobe or rings? Haven't done compression test yet, but performance doesn't seem an issue- car is pulling hard with no problems.
Also...can a faulty MAF cause misfires to only one cylinder?
As strange as it sounds, it has happened. There's a several page thread somewhere on here where someone was troubleshooting a cylinder 2 misfire and a new MAF fixed the problem.
Sent from my iPhone using Tapatalk Pro
IIRC just unplug the MAF it should go to base tables, that should help diagnose it. You didn't mention if you did a compression test on Cylinder 2. A minor leak or tear could cause idle issues that go away under acceleration. How do you know the coil is good or the ICM is?
Sent from my ASUS_Z00TD using Tapatalk
I'll try unplugging the MAF to rule it out. Haven't done a compression test yet--no tester...probably be my next purchase. I swapped 2/5 coil with 3/6 (which wasn't showing any misfires) and the misfires stayed on #2 cylinder. Haven't swapped the ICM out yet but I have a spare GT ICM--know if they are interchangeable? Like you mentioned, starting to think I might have a leak, possibly intake related?
LiM are known for going bad on these cars. Headgaskets not as common. ICM should be interchangeable from non-supercharged. Typically a misfire that doesnt move rules out the coil. Pull the plug and confirm the gap/wire, I know some times the angle for getting plugs in can microcrack them.
