Keko
Hey guys,
I picked up 2002 GTP a few months ago. Started modding it, but now it's getting a little more serious, so here I am. It's a 40th anniversary with 58k miles (got it at 55k!). The two previous owners were both old ladies, so it's going to have a long life.
Current mods:
Downpipe
3.6" pulley
CAI
Autolite 104s
180 tstat
zzp 1.0 tune :/
Solid engine and trans mounts
Mods to come soon:
Front plog
Ported S/C
Ported LIM
Northstar TB
Eventually:
FSIC
I do have a hot start issue if anyone feels compelled to help out. Cold starts are always fine. Once that car has been sitting for ~5 mins or more after driving, starting it can be a chore. The longer it sits, the harder it gets to start. Once it's cold again, it fires right up no problem. Once it's been parked for 5+ mins, what will happen is you start it and it will go up to around 1200 RPM, then it will just fall flat and stall without putting up much of a fight. You have to give it gas for a few seconds to keep it running, and after 5 seconds or so it will keep itself running. If it's been sitting for 30-60 mins it gets really hard to keep it running for the first few seconds. Sometimes some black clouds will shoot out when doing this - it seems to be dumping fuel. Most of the time the idle will bounce around for 15 seconds or maybe more, fluctuating from 500RPM - 1500RPM, and eventually finding it's home around 800. After this hot start condition is hit, accelerating from a stop will bog for a split second when you first tip the throttle in. After that and you are moving, it drives fine, even under full throttle. Also something to note - stft are pretty negative at idle sometimes, even up to -20. While driving, it seems to be in the normal range of +/- 8.
What I've tried so far:
Cleaning MAF
Cleaning TB
Replacing IACV (this helped with starts but didn't fix the issue)
Tested Fuel Pressure Regulator. Took vacuum line off and let car idle for ~3 mins, no fuel came out.
Unplugged MAF - this seemed to help with the issue although I need to do some more testing
Current mods:
Downpipe
3.6" pulley
CAI
Autolite 104s
180 tstat
zzp 1.0 tune :/
Mods to come soon:
Front plog
Ported S/C
Ported LIM
Northstar TB
Eventually:
FSIC
Cleaning MAF
Cleaning TB
