NotEnoughGPs
Member
2002 Grand Prix GT
Stock manifold
2.5" ZZP downpipe
I have a pretty large exhaust leak at the back of the engine. It started small and now there is lots of fumes, and noise, and heat. I believe that the gasket that goes between the stock rear manifold and the ZZP 2.5" downpipe is bad.
First thought was that the rear exhaust manifold gasket was bad, but in other posts, it was revealed that those gaskets don't go bad often.
I can order this gasket from Intense: http://intense-racing.com/Merchant2...oduct_Code=GMG-EMG&Category_Code=3800_Exhaust
Now, what do I need to do to disconnect the downpipe from the manifold? What size are bolts? In order to remove the bolts, where is best place to reach them?
I am not finding much help on exhaust here when seaching
Stock manifold
2.5" ZZP downpipe
