01 Grand Prix GT Metal Clanking noise coming from driverside front wheel
RazerDev
Okay so I went up to the dealership earlier today at about 10 AM, and got the recall done, they got the Valve cover replaced but they also took my engine cover :th_angry-teeth:. But nonetheless I drove it around the lot for a little bit and decided I was satisfied, that was until I got home. When I got home I noticed a metal clanking sound coming from the front left wheel, and it only does it when I turn right, It doesn't matter what speed, but only when I turn right, I tried the same thing in reverse and it doesn't do it, so it only does it when I'm going forward and turning right, kinda weird, if you guys can shed some light on this, I would gladly appreciate it!!
Ill have to look in the morning, but the sway bar looked fine earlier when I was checking everything, But how could that be making the noise? it only does it when I turn right and the wheel is no where near the sway to rub on it or something. This just confuses me
Suspension flex when you turn, it doesn't have to be near the tire to make noise.
Then check for loose tire rods, bearings, springs on the struts. Control arm bushings too.
Ill put her on the jack tommarow and spin the wheels and see if I can isolate it, I'll go ahead check all those too, thanks man! I'll keep you updated
If you replaced the CV axle you were right there. The bars crack where the endlinks go through them and bolt to the arm. You should be able to turn the tires and look behind it to see where this is and see if it is cracked. Mine was only cracked halfway, so it was still attached to the endlink but would pop/clunk when moved.
I'll check it and updated you guys when it's not raining so I can work on her again
Sent from my SM-G920R4 using Tapatalk
Okay so I just put on the new Sway bar link, and I also checked the sway bar and theirs no cracks. I'm at a loss as to whats making the noise.
Okay so I think I figured the general location, its not doing it only when I turn right now, it does it just sitting there but very quietly. It might be the exhaust or something, The right CV axle needs replaced aswell. (Yippe another 100 bucks) and I also need an alignment, ugh so much to do to figure out a damn noise lmfao
I know theirs no play in the rack in pinion at all, Ill check the bolts again though, Where are the other braces located?
I figure you probably don't want to get under the car much, but another thing to check is the starter. Yes, starter. Take the plastic inspection cover off (2 bolts) and try to move the starter gear in and out with your finger. It should move but spring back. If the return spring gets weak or breaks, the starter gear can kiss the flexplate because it can slide over during cornering due to inertia. Makes helluva embarrassing racket if its completely gone bad. Sound is difficult to pinpoint, is intermittent, and it echoes off curbs. Easy to check and you'll know if thats it right away. Replace starter is the fix.
I don't mind being underneath it :P haha, I woulden't even have thought of checking the starter, ill check it in a bit. Ill take a video and some pictures and show you guys whats going on. See yall in a few
Edit: It honestly is embarassing, Iv'e been rerouting to not take right turns a lot, because its so loud and embarassing xP
