    TIPS:
Sale Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,etc.
SgtMarshal
Active member
Cleaning my garage out of all the spare stuff I have been hoarding, everything is plus shipping:
Moog K6662 rear sway bar end link only one side 20 dollars
engine mount that I filled with polyurethane 50 bucks
Four stock length dogbones 30 bucks
Cam key 2 dollars
Snout fill plug 5 dollars
Throttle body spacer 10 bucks
Oil pan gasket 20 dollars
L67 map sensor 20 dollars
L32 map sensor 20 dollars
L36/L26 map sensor (2) 20 dollars
fuel pressure regulator 20 dollars
northstar throttle body throttle position sensor (2) 20 dollars each
L67 throttle position sensor 20 dollars
fuel injector clips 5 dollars
Parts located in Kemmerer, WY 83101
offers accepted, PayPal preferred.
https://drive.google.com/folderview?id=0B6KoWYZT_pmCaE9Bd1hHWVJ2a2s&usp=sharing
Sold:
180* thermostat 10 bucks
zzp poly trans mount, used 50 bucks
intercooler fill adapter 10 bucks
Hud dual gauge pod 20 dollars
Off board pcm tuner with connections for 97-03 and 04+ made by billboost, 50 bucks
Moog 80778 lower control arm bushings should be problem solver 10 bucks
2 Monroe 902973 Strut-Mate Mounting Kit 40 bucks
let me double check those strut mate mounting kits because I thought they were for the front's but it would seem I am wrong.
