compg trailing arm bolts, aluminum or Dorman steel?
spazzz
K guys.
I am replacing the trailing arms and brackets with the Dorman bar and brackets.
The old bracket bolts are aluminum with aluminum studs.
Should I use the old or the new Dorman steel. I am thinking the old aluminum.
In grand GM fashion they only used 3 of the 4 holes in the brackets. Only 1 facing forward where the most tension would be. CompG suspension what a joke.
I have never heard of an aluminum bolt or stud, why would you choose that over steel? Keep in mind I don't know a thing about 04+ GPs.
the armor coated bolts are more desirable, most black oxide/zinc bolts are gonna corrode to **** real quick
Shlt you sayin I should swap the coated in.
Poop, guess I gotta dig through my trash.
edit> found em. I did put a dab of anti-seize on the new ones. Maybe I'll worry about it in another 12 years.
